주요 콘텐츠로 건너뛰기
Pacific Image Electronics CS3600 Motor Replacement
필요한 것
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: 1 단계, 이미지 1/2 Pacific Image Electronics CS3600 Motor Replacement, Motor: 1 단계, 이미지 2/2
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: 2 단계, 이미지 1/1
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: 3 단계, 이미지 1/1
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: 4 단계, 이미지 1/2 Pacific Image Electronics CS3600 Motor Replacement: 4 단계, 이미지 2/2
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: 5 단계, 이미지 1/1
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
결론
Alessia Carlton
회원 가입일: 03/21/17
201 평판
안내서 2개 작성하였습니다
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 232
