주요 콘텐츠로 건너뛰기
Pacific Image Electronics CS3600 Motor Replacement
필요한 것
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: 1 단계, 이미지 2개 중 1개 Pacific Image Electronics CS3600 Motor Replacement, Motor: 1 단계, 이미지 2개 중 2개
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: 4 단계, 이미지 2개 중 1개 Pacific Image Electronics CS3600 Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
결론
작성자
3다른 기여자 명과 함께
Alessia Carlton
회원 가입일: 03/21/17
201 평판
안내서 2개를 작성함
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G2
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 370
