주요 콘텐츠로 건너뛰기
Packard Bell 4X4 Desktop Optical Drive Replacement
필요한 것
  1. Packard Bell 4X4 Desktop Optical Drive Replacement, Top Cover: 1 단계, 이미지 1/1
    • Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
  2. Packard Bell 4X4 Desktop Optical Drive Replacement: 2 단계, 이미지 1/1
    • With both hands on each side of the case, slide the top cover toward you. Lift it off the computer.
  3. Packard Bell 4X4 Desktop Optical Drive Replacement: 3 단계, 이미지 1/1
    • The top cover is removed.
  4. Packard Bell 4X4 Desktop Optical Drive Replacement, Drive Cage: 4 단계, 이미지 1/1
    • Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
  5. Packard Bell 4X4 Desktop Optical Drive Replacement: 5 단계, 이미지 1/1
    • Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
  6. Packard Bell 4X4 Desktop Optical Drive Replacement: 6 단계, 이미지 1/1
    • Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
  7. Packard Bell 4X4 Desktop Optical Drive Replacement: 7 단계, 이미지 1/1
    • Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
  8. Packard Bell 4X4 Desktop Optical Drive Replacement: 8 단계, 이미지 1/1
    • Lift the drive cage up and out of the computer.
  9. Packard Bell 4X4 Desktop Optical Drive Replacement, Optical Drive: 9 단계, 이미지 1/1
    • Remove the 1 Philips head screw with your Phillips screwdriver. There should not be a screw in the right hole.
  10. Packard Bell 4X4 Desktop Optical Drive Replacement: 10 단계, 이미지 1/2 Packard Bell 4X4 Desktop Optical Drive Replacement: 10 단계, 이미지 2/2
    • Slide the optical drive forward and lift it up from the right side, the side closest to the floppy drive.
  11. Packard Bell 4X4 Desktop Optical Drive Replacement: 11 단계, 이미지 1/1
    • Remove the 2 Philips head screws with your Philips screwdriver. Put these screws onto your new optical drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon S
회원 가입일: 09/04/10
490 평판
안내서 3개 작성하였습니다
Packard Bell Planet Packard Bell Planet 회원
Community
1 회원
안내서 6개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 865
