이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will walk you through the process of replacing a bad optical drive in a Packard Bell 4x4 desktop.
필요한 것
Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
Remove the 1 Philips head screw with your Phillips screwdriver. There should not be a screw in the right hole.
다른 한 분이 해당 안내서를 완성하였습니다.
