이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using a Phillips screwdriver, remove the three Phillips head screws (circled in red) from the back of the computer.
With both hands on each side of the case, slide the top cover toward you. Lift it off the computer.
Remove the two Philips head screws with your Philips screwdriver. You may have to lubricate these screws as they can be very difficult to remove.
Remove the 1 Philips head screw from the left hand side of the case if there is one. Again, you may need to lubricate this screw.
Once the screws are removed, disconnect all cables from the optical drive, hard drive and floppy drive.
Slide the drive cage back. An easy way to do this is the push on the optical drive from the front.
Remove the 1 Philips head screw with your Phillips screwdriver. There should not be a screw in the right hole.
Slide the optical drive forward and lift it up from the right side, the side closest to the floppy drive.
Remove the 2 Philips head screws with your Philips screwdriver. Put these screws onto your new optical drive.
다른 한 분이 해당 안내서를 완성하였습니다.
