주요 콘텐츠로 건너뛰기
Packard Bell EasyNote TJ65-CU-030GE Battery Replacement
  1. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 1 단계, 이미지 1/2 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 1 단계, 이미지 2/2
    • The battery is located on the top left corner of the backside of the device.
    • On the left side underneath the battery drawer, you can see two battery lock switches located in the shape of a T.
    • At the beginning, both switches should be switched to the locked position.
  2. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 2 단계, 이미지 1/3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 2 단계, 이미지 2/3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 2 단계, 이미지 3/3
    • Slide the vertical battery lock switch downwards to the image of the unlocked padlock.
    • Now you can move the horizontal battery lock switch to the right.
    • You need to apply some pressure to fully move over the switch. At the hardest part, the battery drawer will spring open.
    • Now you can remove the battery block completely.
    • By doing this, the horizontal switchlock will jump back to its original position on the left side.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jasmin
회원 가입일: 02/17/16
407 평판
안내서 1개 작성함
iFixit EU Team iFixit EU Team 회원
Staff
44 회원들
안내서 1,118개 작성하였습니다
댓글 3개
I am trying to find out how I have managed to turn off the battery on my packardbell easy note ENTG71BM. Any ideas?
julie crockford - 답글
I am tring to turn on the pc, but the only thing it does is making noise of the fan repeatedly without lighting the screen.
siyabonga - 답글
Solution could be as simple as selecting the right video output mode, follow the first hint from the most useful answer in this thread https://it.ifixit.com/Risposte/Visualizz.... If it helped you solve your problem, please feel free to leave a feedback to the author of the post, otherwise I suggest you try asking directly in the above-mentioned dedicated topic
Simone -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 66
전체 시간: 7,569
