필요한 것
Remove the battery.
Unscrew the red marked screws with a Phillips screwdriver.
Remove the DVD reader.
Pry in the red marked spots to release the keyboard
Unplug the keyboard connector.
Unplug the 3 connectors on the motherboard
Remove the 2 screws holding the display in place
Use a thin tool to pry up the back cover of the laptop on the side
Remove the back cover.
Remove the HDD.
Remove the screws that hold the motherboard.
Remove the marked screws and connectors.
Disconnect the display connector.
Remove the display.
Remove the cooling fan.
Remove the heatsink.
Remove the screws on the connector.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
