주요 콘텐츠로 건너뛰기
Palm Centro Back Housing Replacement
필요한 것
  1. Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: 1 단계, 이미지 1/2 Palm Centro Back Housing Replacement, Disassembling Palm Centro Battery: 1 단계, 이미지 2/2
    • Press and slide open the battery cover.
  2. Palm Centro Back Housing Replacement: 2 단계, 이미지 1/1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Back Housing Replacement: 3 단계, 이미지 1/1
    • Phone with battery removed
  4. Palm Centro Back Housing Replacement, Back Housing: 4 단계, 이미지 1/1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Back Housing Replacement: 5 단계, 이미지 1/1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Back Housing Replacement: 6 단계, 이미지 1/2 Palm Centro Back Housing Replacement: 6 단계, 이미지 2/2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Back Housing Replacement: 7 단계, 이미지 1/2 Palm Centro Back Housing Replacement: 7 단계, 이미지 2/2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Back Housing Replacement: 8 단계, 이미지 1/2 Palm Centro Back Housing Replacement: 8 단계, 이미지 2/2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Back Housing Replacement: 9 단계, 이미지 1/2 Palm Centro Back Housing Replacement: 9 단계, 이미지 2/2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chelsea Barackman
회원 가입일: 04/13/10
42 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-49, Garner Spring 2010 Cal Poly, Team 15-49, Garner Spring 2010 회원
CPSU-GARNER-S10S15G49
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 3,787
