주요 콘텐츠로 건너뛰기
Palm Centro Speakers Replacement
필요한 것
  1. Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: 1 단계, 이미지 1/2 Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: 1 단계, 이미지 2/2
    • Press and slide open the battery cover.
  2. Palm Centro Speakers Replacement: 2 단계, 이미지 1/1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Speakers Replacement: 3 단계, 이미지 1/1
    • Phone with battery removed
  4. Palm Centro Speakers Replacement, Back Housing: 4 단계, 이미지 1/1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Speakers Replacement: 5 단계, 이미지 1/1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Speakers Replacement: 6 단계, 이미지 1/2 Palm Centro Speakers Replacement: 6 단계, 이미지 2/2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Speakers Replacement: 7 단계, 이미지 1/2 Palm Centro Speakers Replacement: 7 단계, 이미지 2/2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Speakers Replacement: 8 단계, 이미지 1/2 Palm Centro Speakers Replacement: 8 단계, 이미지 2/2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Speakers Replacement: 9 단계, 이미지 1/2 Palm Centro Speakers Replacement: 9 단계, 이미지 2/2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Speakers Replacement, Logic Board: 10 단계, 이미지 1/1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Speakers Replacement: 11 단계, 이미지 1/1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Speakers Replacement: 12 단계, 이미지 1/1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Speakers Replacement, Speakers: 13 단계, 이미지 1/3 Palm Centro Speakers Replacement, Speakers: 13 단계, 이미지 2/3 Palm Centro Speakers Replacement, Speakers: 13 단계, 이미지 3/3
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  14. Palm Centro Speakers Replacement: 14 단계, 이미지 1/1
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin
회원 가입일: 04/12/10
31 평판
안내서 1개 작성함
Cal Poly, Team 15-49, Garner Spring 2010 Cal Poly, Team 15-49, Garner Spring 2010 회원
CPSU-GARNER-S10S15G49
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,487
