주요 콘텐츠로 건너뛰기
Palm IIIc Battery Replacement
필요한 것
  1. Palm IIIc Battery Replacement, Removing broken LCD screen: 1 단계, 이미지 1/1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Battery Replacement: 2 단계, 이미지 1/1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Battery Replacement, Remove the Front Cover: 3 단계, 이미지 1/1
    • Lay Palm IIIc face-up and remove the front cover.
    • Do this firmly but not with too much force so as to not break or disturb anything you're not supposed to.
  4. Palm IIIc Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Carefully pop out the battery, without disturbing the surroundings.
    • Prying tool will facilitate this step.
  5. Palm IIIc Battery Replacement: 5 단계, 이미지 1/1
    • Detach the wire connecting the battery to the motherboard.
  6. Palm IIIc Battery Replacement: 6 단계, 이미지 1/1
    • Attach the new battery by connecting it to the motherboard via the red wire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Paulina Trujillo
회원 가입일: 04/07/11
265 평판
안내서 8개 작성하였습니다
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G69
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 18
전체 시간: 4,183
