주요 콘텐츠로 건너뛰기
Palm IIIc Screen Replacement
필요한 것
  1. Palm IIIc Screen Replacement, Removing broken LCD screen: 1 단계, 이미지 1개 중 1개
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Screen Replacement, Remove the Front and Back Covers: 3 단계, 이미지 1개 중 1개
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Palm IIIc Screen Replacement, Screen: 4 단계, 이미지 1개 중 1개
    • Unhook the battery cable from the motherboard and remove the battery.
  5. Palm IIIc Screen Replacement: 5 단계, 이미지 2개 중 1개 Palm IIIc Screen Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • On the back of the motherboard use tweezers to pull up the ZIF connector which looks like a brown plastic tab.
    • Once the ZIF connector is unattached, remove the clear screen cover.
  6. Palm IIIc Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Using tweezers unhook the blue and red screen cables where they connect to the motherboard.
  7. Palm IIIc Screen Replacement: 7 단계, 이미지 3개 중 1개 Palm IIIc Screen Replacement: 7 단계, 이미지 3개 중 2개 Palm IIIc Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Using tweezers, pull up the other two ZIF connector tabs.
  8. Palm IIIc Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Gently pull the black clips on the inside case to detach the motherboard from the device. Pull the motherboard out towards the bottom left corner.
  9. Palm IIIc Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the screen out from the front.
결론
작성자
6다른 기여자 명과 함께
Paulina Trujillo
회원 가입일: 04/07/11
265 평판
안내서 8개를 작성함
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G69
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 16
전체 시간: 1,143
