주요 콘텐츠로 건너뛰기
Palm IIIx Front Button Cluster Replacement
필요한 것
  1. Palm IIIx Front Button Cluster Replacement, Battery: 1 단계, 이미지 1/1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Front Button Cluster Replacement: 2 단계, 이미지 1/1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Front Button Cluster Replacement: 3 단계, 이미지 1/1
    • Remove the old batteries one at a time.
  4. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: 4 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Front Button Cluster Replacement: 5 단계, 이미지 1/1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Palm IIIx Front Button Cluster Replacement: 6 단계, 이미지 1/1
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Palm IIIx Front Button Cluster Replacement: 7 단계, 이미지 1/1
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
결론
David Haskell
회원 가입일: 01/21/10
44 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-43, Regan Winter 2010 Cal Poly, Team 14-43, Regan Winter 2010 회원
CPSU-REGAN-W10S14G43
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,332
