주요 콘텐츠로 건너뛰기
Palm IIIx Motherboard Assembly Replacement
필요한 것
  1. Palm IIIx Motherboard Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Motherboard Assembly Replacement: 2 단계, 이미지 1/1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Motherboard Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the old batteries one at a time.
  4. Palm IIIx Motherboard Assembly Replacement, Motherboard Assembly: 4 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Motherboard Assembly Replacement: 5 단계, 이미지 1/1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Motherboard Assembly Replacement: 6 단계, 이미지 1/1
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Motherboard Assembly Replacement: 7 단계, 이미지 1/2 Palm IIIx Motherboard Assembly Replacement: 7 단계, 이미지 2/2
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Motherboard Assembly Replacement: 8 단계, 이미지 1/1
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Motherboard Assembly Replacement: 9 단계, 이미지 1/1
    • Separate the motherboard from the screen.
  10. Palm IIIx Motherboard Assembly Replacement: 10 단계, 이미지 1/1
    • Now the motherboard assembly can be replaced successfully.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ben Johnson
회원 가입일: 01/26/10
22 평판
안내서 1개 작성함
Cal Poly, Team 14-43, Regan Winter 2010 Cal Poly, Team 14-43, Regan Winter 2010 회원
CPSU-REGAN-W10S14G43
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 3,072
