주요 콘텐츠로 건너뛰기
Palm P101UNA Charger Outlet Replacement
필요한 것
  1. Palm P101UNA Charger Outlet Replacement, Battery: 1 단계, 이미지 1/1
    • Push in the button at the bottom of the phone, and lift the back cap off.
  2. Palm P101UNA Charger Outlet Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling out the little tab.
  3. Palm P101UNA Charger Outlet Replacement, Charger Outlet: 3 단계, 이미지 1/1
    • Turn phone over on its left side and remove single phillip's head screw using the Phillips #0 screwdriver.
  4. Palm P101UNA Charger Outlet Replacement: 4 단계, 이미지 1/1
    • After screw is removed take the plastic opening tool and apply slight pressure to even out bends in the metal
  5. Palm P101UNA Charger Outlet Replacement: 5 단계, 이미지 1/1
    • Insert charger to check adjustments to metal outlet
결론
ironwill13791
회원 가입일: 10/30/13
509 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S2G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 248
