주요 콘텐츠로 건너뛰기
Palm Pre Keyboard Replacement
필요한 것
  1. Palm Pre Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Keyboard Replacement: 2 단계, 이미지 1/1
    • Carefully pull up on the tab to remove the current battery.
  3. Palm Pre Keyboard Replacement, Antenna: 3 단계, 이미지 1/2 Palm Pre Keyboard Replacement, Antenna: 3 단계, 이미지 2/2
    • Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
  4. Palm Pre Keyboard Replacement: 4 단계, 이미지 1/1
    • Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
    • Use a spudger to pry open the hinge.
    • Use tweezers to disconnect the antennas from the keypad control board.
  5. Palm Pre Keyboard Replacement: 5 단계, 이미지 1/2 Palm Pre Keyboard Replacement: 5 단계, 이미지 2/2
    • Use a spudger to pry off the (black and yellow) back frame.
    • Disregard the main part of the phone at this point and look only at the inside of the removed back frame. (You will need the main part of the phone for access to the keyboard and motherboard)
  6. Palm Pre Keyboard Replacement: 6 단계, 이미지 1/1
    • Find the small circuit board at the top right and desolder the wires that are connected to it.
    • This step is only necessary for antenna removal.
  7. Palm Pre Keyboard Replacement, Keypad Control Board: 7 단계, 이미지 1/1
    • Remove the two ribbon cable connectors using tweezers.
  8. Palm Pre Keyboard Replacement: 8 단계, 이미지 1/2 Palm Pre Keyboard Replacement: 8 단계, 이미지 2/2
    • Use a spudger to remove the keypad control board.
    • There is heavy adhesive connecting this part to the keypad sensors.
  9. Palm Pre Keyboard Replacement, Keyboard: 9 단계, 이미지 1/1
    • Slide the keyboard away from the phone.
    • Use tweezers to separate the keyboard from the phone if adhesive is inhibiting removal.
결론
noha
회원 가입일: 04/12/12
139 평판
안내서 6개 작성하였습니다
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 회원
CPSU-MANESS-S12S7G31
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,275
