주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm Rest Disassembly
필요한 것
  1. Palm Rest Disassembly, Battery: 1 단계, 이미지 1개 중 1개
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. Palm Rest Disassembly: 2 단계, 이미지 2개 중 1개 Palm Rest Disassembly: 2 단계, 이미지 2개 중 2개
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. Palm Rest Disassembly: 3 단계, 이미지 2개 중 1개 Palm Rest Disassembly: 3 단계, 이미지 2개 중 2개
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. Palm Rest Disassembly: 4 단계, 이미지 2개 중 1개 Palm Rest Disassembly: 4 단계, 이미지 2개 중 2개
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. Palm Rest Disassembly: 5 단계, 이미지 3개 중 1개 Palm Rest Disassembly: 5 단계, 이미지 3개 중 2개 Palm Rest Disassembly: 5 단계, 이미지 3개 중 3개
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. Palm Rest Disassembly, Palm Rest Disassembly: 6 단계, 이미지 1개 중 1개
    • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
  7. Palm Rest Disassembly: 7 단계, 이미지 1개 중 1개
    • Pry up and detach the keyboard. Starting at the top, slowly work the side and pull the keyboard away from you to unseat the bottom tabs.
  8. Palm Rest Disassembly: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
  9. Palm Rest Disassembly: 9 단계, 이미지 2개 중 1개 Palm Rest Disassembly: 9 단계, 이미지 2개 중 2개
    • Remove the palm rest using the blue spudger tool.
  10. Palm Rest Disassembly: 10 단계, 이미지 1개 중 1개
    • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
  11. Palm Rest Disassembly: 11 단계, 이미지 1개 중 1개
    • Remove metal keyboard underlayment.
    • There is no way to separate the palm rest from the keyboard. They both are removed as an assembly.
결론
작성자
4다른 기여자 명과 함께
Benjamin Poirier
회원 가입일: 10/17/17
503 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 UMass Dartmouth, Team S1-G4, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 100
전체 시간: 1,729
