소개
This guide will walk you through the steps to remove and replace the front panel on a Palm T|X.
필요한 것
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
Orient the device sideways, as shown in the picture.
Lightly push the front of the display to separate it from the front panel.
Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
다른 2명이 해당 안내서를 완성하였습니다.
