주요 콘텐츠로 건너뛰기
Palm TX Motherboard Replacement
필요한 것
  1. Palm TX Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 Palm TX Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Motherboard Replacement: 2 단계, 이미지 1/1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Motherboard Replacement: 3 단계, 이미지 1/2 Palm TX Motherboard Replacement: 3 단계, 이미지 2/2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Motherboard Replacement: 4 단계, 이미지 1/2 Palm TX Motherboard Replacement: 4 단계, 이미지 2/2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Motherboard Replacement: 5 단계, 이미지 1/2 Palm TX Motherboard Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Motherboard Replacement, Battery Pack: 6 단계, 이미지 1/2 Palm TX Motherboard Replacement, Battery Pack: 6 단계, 이미지 2/2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 Palm TX Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Motherboard Replacement: 8 단계, 이미지 1/2 Palm TX Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
결론
Spencer Lewson
회원 가입일: 01/19/11
793 평판
안내서 6개 작성하였습니다
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G15
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 3,428
