주요 콘텐츠로 건너뛰기
Palm Treo 600 Camera Replacement
필요한 것
  1. Palm Treo 600 Camera Replacement, Back Case: 1 단계, 이미지 1/1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Camera Replacement: 2 단계, 이미지 1/2 Palm Treo 600 Camera Replacement: 2 단계, 이미지 2/2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Camera Replacement: 3 단계, 이미지 1/2 Palm Treo 600 Camera Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Camera Replacement, Motherboard: 4 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  5. Palm Treo 600 Camera Replacement: 5 단계, 이미지 1/1
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  6. Palm Treo 600 Camera Replacement: 6 단계, 이미지 1/1
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  7. Palm Treo 600 Camera Replacement: 7 단계, 이미지 1/2 Palm Treo 600 Camera Replacement: 7 단계, 이미지 2/2
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
  8. Palm Treo 600 Camera Replacement, Camera: 8 단계, 이미지 1/2 Palm Treo 600 Camera Replacement, Camera: 8 단계, 이미지 2/2
    • Using the flat end of the spudger, lift the metal case off of the camera.
  9. Palm Treo 600 Camera Replacement: 9 단계, 이미지 1/3 Palm Treo 600 Camera Replacement: 9 단계, 이미지 2/3 Palm Treo 600 Camera Replacement: 9 단계, 이미지 3/3
    • Slide the flat end of the spudger between the printed circuit board and metal holder.
    • Pop the camera up
결론
Clement Poisson
회원 가입일: 01/26/10
24 평판
안내서 7개 작성하였습니다
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 회원
CPSU-MANESS-W10S13G23
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,534
