주요 콘텐츠로 건너뛰기
Palm Treo 600 Keyboard Replacement
필요한 것
  1. Palm Treo 600 Keyboard Replacement, Back Case: 1 단계, 이미지 1/1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Keyboard Replacement: 2 단계, 이미지 1/2 Palm Treo 600 Keyboard Replacement: 2 단계, 이미지 2/2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Keyboard Replacement: 3 단계, 이미지 1/2 Palm Treo 600 Keyboard Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Keyboard Replacement, Front Case: 4 단계, 이미지 1/2 Palm Treo 600 Keyboard Replacement, Front Case: 4 단계, 이미지 2/2
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Palm Treo 600 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/1
    • Using the spudger, flip open the clasp that holds the data ribbon in place.
  6. Palm Treo 600 Keyboard Replacement: 6 단계, 이미지 1/1
    • Pull out the ribbon.
    • The keyboard will disconnect from the phone.
결론
Clement Poisson
회원 가입일: 01/26/10
24 평판
안내서 7개 작성하였습니다
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 회원
CPSU-MANESS-W10S13G23
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 1,492
