주요 콘텐츠로 건너뛰기
Palm Treo 650 Camera Replacement
필요한 것
  1. Palm Treo 650 Camera Replacement, Battery and Stylus: 1 단계, 이미지 1/1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Camera Replacement: 2 단계, 이미지 1/1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Camera Replacement: 3 단계, 이미지 1/2 Palm Treo 650 Camera Replacement: 3 단계, 이미지 2/2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Camera Replacement, Case: 4 단계, 이미지 1/1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Camera Replacement: 5 단계, 이미지 1/2 Palm Treo 650 Camera Replacement: 5 단계, 이미지 2/2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Camera Replacement: 6 단계, 이미지 1/1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Camera Replacement: 7 단계, 이미지 1/2 Palm Treo 650 Camera Replacement: 7 단계, 이미지 2/2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Camera Replacement, Camera: 8 단계, 이미지 1/3 Palm Treo 650 Camera Replacement, Camera: 8 단계, 이미지 2/3 Palm Treo 650 Camera Replacement, Camera: 8 단계, 이미지 3/3
    • Remove the two 3.75 mm screws.
    • Pull off the logic board.
  9. Palm Treo 650 Camera Replacement: 9 단계, 이미지 1/3 Palm Treo 650 Camera Replacement: 9 단계, 이미지 2/3 Palm Treo 650 Camera Replacement: 9 단계, 이미지 3/3
    • Pull the rubber ring off of the camera.
  10. Palm Treo 650 Camera Replacement: 10 단계, 이미지 1/2 Palm Treo 650 Camera Replacement: 10 단계, 이미지 2/2
    • Pry off the metal camera case.
    • Lift up the camera, but do not remove. The connector must be detatched first.
  11. Palm Treo 650 Camera Replacement: 11 단계, 이미지 1/2 Palm Treo 650 Camera Replacement: 11 단계, 이미지 2/2
    • Pry off the camera connector plug.
    • Remove the camera.
결론
cgood
회원 가입일: 10/28/09
122 평판
안내서 7개 작성하였습니다
Cal Poly, Team 19-3, Maness Fall 2009 Cal Poly, Team 19-3, Maness Fall 2009 회원
CPSU-MANESS-F09S19G3
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 13
전체 시간: 2,129
