주요 콘텐츠로 건너뛰기
소개
This guide will help you take apart, clean, and (if necessary) replace the palm treo keyboard.
  1. Position the phone so the screen faces down.
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. To remove the battery cover, hold down the button in the middle of the phone's back.
    • To remove the battery cover, hold down the button in the middle of the phone's back.
    • Slide the cover down to remove. Set the cover aside.
  3. Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Remove the small round rubber cover on the back of the phone located immediately below the antenna.
    • Remove the small round rubber cover on the back of the phone located immediately below the antenna.
    • This will uncover a screw that will be removed in the next step.
  5. PC 노트북 배터리
    자사가 품질을 보증하는 모든 최고 PC 브랜드 배터리.
    지금 장보기
    PC 노트북 배터리
    지금 장보기
  6. Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver. Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver. Pull out antenna.
    • Unscrew six black 6.9 mm Torx screws with a T5 Torx Screwdriver.
    • Unscrew one 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
    • Pull out antenna.
  7. Pry the back cover off using a spudger or similar tool. The back cover is attached by several small clips on the inside.
    • Pry the back cover off using a spudger or similar tool.
    • The back cover is attached by several small clips on the inside.
  8. Unclip the gray tab. Pull out the orange ribbon cable. Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
    • Do not remove the motherboard before disconnecting the ribbon cable--Damage may occur!
  9. Pull off the mother board. Install replacement or repaired motherboard, reversing steps above.
    • Pull off the mother board.
    • Install replacement or repaired motherboard, reversing steps above.
  10. Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
    • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
  11. Pull off the circuit board.
    • Pull off the circuit board.
  12. Remove the keypad for cleaning or replacing.
    • Remove the keypad for cleaning or replacing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
cgood
회원 가입일: 2009년 10월 28일
119 평판
안내서 7개 작성하였습니다
Cal Poly, Team 19-3, Maness Fall 2009 Cal Poly, Team 19-3, Maness Fall 2009 회원
CPSU-MANESS-F09S19G3
4 회원들
안내서 18개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 4,529
