소개
This guide will show how to separate the battery from the phone.
  1. Position the phone so the screen faces down.
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. To remove the battery cover, hold down the button in the middle of the phone's back.
    • To remove the battery cover, hold down the button in the middle of the phone's back.
    • Slide the cover down to remove. Set the cover aside.
  4. Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
결론
다른 4명이 해당 안내서를 완성하였습니다.
cgood
회원 가입일: 2009년 10월 28일
116 평판
안내서 7개 작성하였습니다
Cal Poly, Team 19-3, Maness Fall 2009 Cal Poly, Team 19-3, Maness Fall 2009 회원
CPSU-MANESS-F09S19G3
4 회원들
안내서 18개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 3,391
