이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
Remove the 27mm screw using the T6 Torx screwdriver.
Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
Turn the phone so the screen is facing the right side.
Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
Separate the covers from the left side of the device as indicated in the picture.
