이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press the button located just above the Sprint™ logo and then slide the cover down.
Use the small notch on the left hand side of the phone to remove the battery.
After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
Using the spudger, remove the small rubberized patch under the antenna.
Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
The antenna will now be loose, gently pull the antenna out of the phone.
