주요 콘텐츠로 건너뛰기
Palm Treo 700P Keypad Replacement
필요한 것
  1. Palm Treo 700P Keypad Replacement, Battery: 1 단계, 이미지 1/3 Palm Treo 700P Keypad Replacement, Battery: 1 단계, 이미지 2/3 Palm Treo 700P Keypad Replacement, Battery: 1 단계, 이미지 3/3
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Keypad Replacement: 2 단계, 이미지 1/2 Palm Treo 700P Keypad Replacement: 2 단계, 이미지 2/2
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Keypad Replacement, Back Case: 3 단계, 이미지 1/1
    • Remove the stylus from the phone.
  4. Palm Treo 700P Keypad Replacement: 4 단계, 이미지 1/1
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Palm Treo 700P Keypad Replacement: 5 단계, 이미지 1/1
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Keypad Replacement: 6 단계, 이미지 1/1
    • Unscrew the last two screws using the previous screw driver.
  7. Palm Treo 700P Keypad Replacement: 7 단계, 이미지 1/2 Palm Treo 700P Keypad Replacement: 7 단계, 이미지 2/2
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Palm Treo 700P Keypad Replacement, Motherboard: 8 단계, 이미지 1/3 Palm Treo 700P Keypad Replacement, Motherboard: 8 단계, 이미지 2/3 Palm Treo 700P Keypad Replacement, Motherboard: 8 단계, 이미지 3/3
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Palm Treo 700P Keypad Replacement: 9 단계, 이미지 1/3 Palm Treo 700P Keypad Replacement: 9 단계, 이미지 2/3 Palm Treo 700P Keypad Replacement: 9 단계, 이미지 3/3
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Palm Treo 700P Keypad Replacement: 10 단계, 이미지 1/2 Palm Treo 700P Keypad Replacement: 10 단계, 이미지 2/2
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. Palm Treo 700P Keypad Replacement: 11 단계, 이미지 1/3 Palm Treo 700P Keypad Replacement: 11 단계, 이미지 2/3 Palm Treo 700P Keypad Replacement: 11 단계, 이미지 3/3
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
  12. Palm Treo 700P Keypad Replacement, LCD: 12 단계, 이미지 1/1
    • Once the motherboard is removed, the LCD should be resting on the front case of the phone.
  13. Palm Treo 700P Keypad Replacement, Keypad: 13 단계, 이미지 1/1
    • Peel the keypad from the front panel of the case
  14. Palm Treo 700P Keypad Replacement: 14 단계, 이미지 1/1
    • Using a spudger, remove the gel keyboard from the front case.
결론
James Smith
회원 가입일: 04/27/12
10 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-37, Regan Spring 2012 Cal Poly, Team 12-37, Regan Spring 2012 회원
CPSU-REGAN-S12S12G37
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 656
