주요 콘텐츠로 건너뛰기
Palm Zire 31 Keys Replacement
필요한 것
  1. Palm Zire 31 Keys Replacement, Case: 1 단계, 이미지 1/1
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Keys Replacement: 2 단계, 이미지 1/1
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Keys Replacement: 3 단계, 이미지 1/1
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Keys Replacement: 4 단계, 이미지 1/1
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Keys Replacement, Keys: 5 단계, 이미지 1/1
    • The blue keys will either come off with the blue front case, or stay on the motherboard.
결론
Gabe
회원 가입일: 01/23/11
501 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-21, Amido Winter 2011 Cal Poly, Team 5-21, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G21
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 596
