주요 콘텐츠로 건너뛰기
Palm Zire 71 Back Cover Replacement
필요한 것
  1. Palm Zire 71 Back Cover Replacement, Preparation: 1 단계, 이미지 1/1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Back Cover Replacement, Top Screws (2) Removal: 2 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Back Cover Replacement, Bottom Screws (3) Removal: 3 단계, 이미지 1/1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Back Cover Replacement, Front Panel Removal: 4 단계, 이미지 1/2 Palm Zire 71 Back Cover Replacement, Front Panel Removal: 4 단계, 이미지 2/2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: 5 단계, 이미지 1/2 Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: 5 단계, 이미지 2/2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Back Cover Replacement, Back Cover: 6 단계, 이미지 1/2 Palm Zire 71 Back Cover Replacement, Back Cover: 6 단계, 이미지 2/2
    • Slide the back cover off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jinxian Jiang
회원 가입일: 04/28/11
245 평판
안내서 3개 작성하였습니다
CSU Los Angeles, Team 1-5, Nelson Spring 2011 CSU Los Angeles, Team 1-5, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 2,485
