주요 콘텐츠로 건너뛰기
Palm Zire 71 Battery Replacement
필요한 것
  1. Palm Zire 71 Battery Replacement, Preparation: 1 단계, 이미지 1/1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Battery Replacement, Top Screws (2) Removal: 2 단계, 이미지 1/1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Battery Replacement, Bottom Screws (3) Removal: 3 단계, 이미지 1/1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Battery Replacement, Front Panel Removal: 4 단계, 이미지 1/2 Palm Zire 71 Battery Replacement, Front Panel Removal: 4 단계, 이미지 2/2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: 5 단계, 이미지 1/2 Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: 5 단계, 이미지 2/2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Battery Replacement, Back Cover: 6 단계, 이미지 1/2 Palm Zire 71 Battery Replacement, Back Cover: 6 단계, 이미지 2/2
    • Slide the back cover off.
  7. Palm Zire 71 Battery Replacement, Battery: 7 단계, 이미지 1/1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Battery Replacement: 8 단계, 이미지 1/2 Palm Zire 71 Battery Replacement: 8 단계, 이미지 2/2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Battery Replacement: 9 단계, 이미지 1/3 Palm Zire 71 Battery Replacement: 9 단계, 이미지 2/3 Palm Zire 71 Battery Replacement: 9 단계, 이미지 3/3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Battery Replacement: 10 단계, 이미지 1/3 Palm Zire 71 Battery Replacement: 10 단계, 이미지 2/3 Palm Zire 71 Battery Replacement: 10 단계, 이미지 3/3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jinxian Jiang
회원 가입일: 04/28/11
245 평판
안내서 3개 작성하였습니다
CSU Los Angeles, Team 1-5, Nelson Spring 2011 CSU Los Angeles, Team 1-5, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 25
전체 시간: 9,116
