소개
This guide is to show you how to replace the battery on Palm Zire 71.
필요한 것
Flip the phone so it's facing screen-side down.
Slide the back cover upward to open.
Remove the back sticker.
Remove the three bottom Phillips #00 screws.
Flip the phone over so it's facing screen-side up.
Slide the screen upward by a few millimeters without detaching the screen.
Use the plastic opening tool to pry off the front panel.
Remove the bottom two Phillips #00 screws.
Remove the bracket.
Use the plastic opening tool to pry off the speaker.
다른 7명이 해당 안내서를 완성하였습니다.
