주요 콘텐츠로 건너뛰기
Palm Zire m150 Battery Replacement
필요한 것
  1. Palm Zire m150 Battery Replacement, Battery: 1 단계, 이미지 1/2 Palm Zire m150 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • To begin, gently pull on the flap to remove.
  2. Palm Zire m150 Battery Replacement: 2 단계, 이미지 1/1
    • Use T6 bit of screwdriver provided in the iFixit toolkit. Unscrew the two screws at the top of the device.
  3. Palm Zire m150 Battery Replacement: 3 단계, 이미지 1/2 Palm Zire m150 Battery Replacement: 3 단계, 이미지 2/2
    • Carefully remove the back panel of the device.
  4. Palm Zire m150 Battery Replacement: 4 단계, 이미지 1/2 Palm Zire m150 Battery Replacement: 4 단계, 이미지 2/2
    • Gently remove the battery from the phone.
  5. Palm Zire m150 Battery Replacement: 5 단계, 이미지 1/1
    • Insert new battery where old battery was.
    • To reassemble your device, follow these steps in reverse order
결론
Kate
회원 가입일: 01/26/16
528 평판
안내서 5개 작성하였습니다
USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 회원
USFSM-STEWART-S16S1G3
5 회원들
안내서 7개 작성하였습니다
댓글 한 개
Why is nothing said about soldering of battery terminals, which I read elsewhere as a requirement?
Carlton Barnett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 29
전체 시간: 1,311
