소개
This guide will teach you how to replace the control button on your Palm Zire m150. If you don't need to replace it, it will also teach you how to take the device apart in order to clean the control button.
필요한 것
Lift up the flap on the Palm Zire M150.
If you wish to remove it, gently lift up on the flap and pull horizontally. It should come off without an issue.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
