주요 콘텐츠로 건너뛰기
Palm Zire m150 Motherboard Replacement
필요한 것
  1. Palm Zire m150 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Lift up the flap on the Palm Zire M150.
    • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
    • If you wish to remove it, gently lift up and pull horizontally. It should come off without an issue.
  2. Palm Zire m150 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
  3. Palm Zire m150 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Palm Zire m150 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull the top cover off the device using both hands.
  4. Palm Zire m150 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screen from the motherboard.
    • Be careful not to break the connector that connects the screen to motherboard.
  5. Palm Zire m150 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully remove the battery by prying up away from the motherboard.
    • Battery is glued to motherboard.
    • Remove the positive and negative terminals from the motherboard.
    • Slowly remove the motherboard by lifting upward and out of the bottom case housing.
  6. Palm Zire m150 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Palm Zire m150 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Insert NEW motherboard into the bottom case housing.
    • On the NEW motherboard, use a soldering iron to solder the positive and negative terminals to the new motherboard.
    • Let solder cool before reassembling unit.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kate
회원 가입일: 01/26/16
528 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 524
