주요 콘텐츠로 건너뛰기
Palm m 100 Batteries Replacement
  1. Palm m 100 Batteries Replacement, Batteries: 1 단계, 이미지 1/1
    • Take the battery cover off by pushing down on the tab and lifting off.
  2. Palm m 100 Batteries Replacement: 2 단계, 이미지 1/1
    • Make sure batteries are there.
  3. Palm m 100 Batteries Replacement: 3 단계, 이미지 1/1
    • Check the type of batteries to be sure they are both AAA batteries.
    • Make sure they are installed in the right direction by taking the batteries out, aligning the positive side with the positive side and the negative side with the negative side.
  4. Palm m 100 Batteries Replacement: 5 단계, 이미지 1/1
    • Once positive that the batteries are installed correctly, press the on/off located at the top center of the device.
    • If the device still does not turn on, repeat the previous steps with a fresh set of AAA batteries.
결론
Anne Carey
회원 가입일: 10/25/11
1 평판
안내서 3개 작성하였습니다
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 회원
JMU-ALLEN-F11S1G3
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 9
전체 시간: 603
