주요 콘텐츠로 건너뛰기
Palm m 100 Cover Replacement
필요한 것
  1. Palm m 100 Cover Replacement, Cover: 1 단계, 이미지 1/1
    • Remove the batteries.
  2. Palm m 100 Cover Replacement: 2 단계, 이미지 1/1
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Cover Replacement: 3 단계, 이미지 1/3 Palm m 100 Cover Replacement: 3 단계, 이미지 2/3 Palm m 100 Cover Replacement: 3 단계, 이미지 3/3
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  4. Palm m 100 Cover Replacement: 4 단계, 이미지 1/1
    • Set aside broken cover, and replace with a new cover.
  5. Palm m 100 Cover Replacement: 5 단계, 이미지 1/1
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  6. Palm m 100 Cover Replacement: 6 단계, 이미지 1/1
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
결론
Anne Carey
회원 가입일: 10/25/11
1 평판
안내서 3개 작성하였습니다
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 회원
JMU-ALLEN-F11S1G3
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 549
