주요 콘텐츠로 건너뛰기
Palm m 100 Display Screen Replacement
필요한 것
  1. Palm m 100 Display Screen Replacement, Display Screen: 1 단계, 이미지 1/1
    • Remove the batteries.
  2. Palm m 100 Display Screen Replacement: 2 단계, 이미지 1/1
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Display Screen Replacement: 3 단계, 이미지 1/1
    • Remove rear cover by gently lifting it up from the bottom.
  4. Palm m 100 Display Screen Replacement: 4 단계, 이미지 1/1
    • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Lift the left side of the circuit board and open it as though it were a book.
  5. Palm m 100 Display Screen Replacement: 6 단계, 이미지 1/1
    • Unplug the three connectors located on the right side of the circuit board with great caution and care. Do not pull by the cable, and be sure to pull the connector itself gently.
    • After separating the screen from the board, set aside the old display screen.
    • Replace with a new display screen.
  6. Palm m 100 Display Screen Replacement: 9 단계, 이미지 1/1
    • Plug in the three connectors.
  7. Palm m 100 Display Screen Replacement: 10 단계, 이미지 1/1
    • Close again like a book, and lay it gently into the front panel, screen facing outwards of the front panel.
  8. Palm m 100 Display Screen Replacement: 11 단계, 이미지 1/1
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
결론
Lexi Gallucci
회원 가입일: 10/18/11
11 평판
안내서 2개 작성하였습니다
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 회원
JMU-ALLEN-F11S1G3
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 11
전체 시간: 694
