주요 콘텐츠로 건너뛰기
Palm m 100 Display Screen Replacement
필요한 것
  1. Palm m 100 Display Screen Replacement, Display Screen: 1 단계, 이미지 1개 중 1개
    • Remove the batteries.
  2. Palm m 100 Display Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Display Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove rear cover by gently lifting it up from the bottom.
  4. Palm m 100 Display Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Lift the left side of the circuit board and open it as though it were a book.
  5. Palm m 100 Display Screen Replacement: 5 단계, 이미지 2개 중 1개 Palm m 100 Display Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Unplug the three connectors located on the right side of the circuit board with great caution and care.
    • Slide the cables out gently using a spudger
    • Separate the screen from the board.
결론
작성자
5다른 기여자 명과 함께
Lexi Gallucci
회원 가입일: 10/18/11
11 평판
안내서 2개를 작성함
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 회원
JMU-ALLEN-F11S1G3
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 12
전체 시간: 804
