소개
You will need to have a supply of AAA batteries for replacement. Can be found at most hardware and department stores. You can also order them online here
Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
댓글 한 개
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
