주요 콘텐츠로 건너뛰기
Palm m105 Batteries Replacement
  1. Palm m105 Batteries Replacement, Batteries: 1 단계, 이미지 1/1
    • Press the latch on the battery door on the back of the device and pull outwards.
    • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
  2. Palm m105 Batteries Replacement: 2 단계, 이미지 1/1
    • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
    • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
  3. Palm m105 Batteries Replacement: 3 단계, 이미지 1/1
    • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
결론
Erik Thompson
회원 가입일: 10/04/11
31 평판
안내서 5개 작성하였습니다
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 1,226
