메인 콘텐츠로 스킵하기
소개
In this guide you will learn how to remove the necessary parts to clean or replace the button board.
The Palm m105 is a device with several different parts. Maintenance takes less than ten minutes to complete.
부품
지정된 부품이 없습니다.
  1. Begin with the Palm m105 facing you on a flat surface.
    • Begin with the Palm m105 facing you on a flat surface.
  2. Remove protective screen cover by flipping up and pulling directly up from the top of the device.
    • Remove protective screen cover by flipping up and pulling directly up from the top of the device.
    • The two clips located on the protective screen will pop out.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Remove Faceplate. There is a tab right where the finger is located that needs to be pulled up.
    • Remove Faceplate. There is a tab right where the finger is located that needs to be pulled up.
    • The Faceplate will then easily lift off.
  5. Unscrew all four screws with the T-5 Torx screwdriver. There is one screw per corner. Turn counter clockwise to remove screws. The link to purchase this screwdriver is Located here. Once you have removed all of the screws the device will be in three separate pieces (the back, the computer and the button board. Be careful because the power button is loose once you have performed this step.
    • Unscrew all four screws with the T-5 Torx screwdriver. There is one screw per corner. Turn counter clockwise to remove screws. The link to purchase this screwdriver is Located here. Once you have removed all of the screws the device will be in three separate pieces (the back, the computer and the button board.
    • Be careful because the power button is loose once you have performed this step.
  6. You can see where the buttons were placed. To remove the buttons from the holder you need to  push evenly on two buttons at a time, this will make them pop out easily. Once you have removed the buttons you can now wash or replace the buttons with new buttons.
    • You can see where the buttons were placed. To remove the buttons from the holder you need to push evenly on two buttons at a time, this will make them pop out easily. Once you have removed the buttons you can now wash or replace the buttons with new buttons.
    • To replace the new buttons push them back the way they were and you should feel them click into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erik Thompson
회원 가입일: 2011년 10월 04일
31 평판
안내서 5개 작성하였습니다
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G3
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 357
