주요 콘텐츠로 건너뛰기
Palm m105 Button Replacement
필요한 것
  1. Palm m105 Button Replacement, Buttons: 1 단계, 이미지 1개 중 1개
    • Begin with the Palm m105 facing you on a flat surface.
  2. Palm m105 Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the protective screen cover by flipping it up and pulling it directly away from the top of the device.
    • The two clips located on the protective screen should pop out.
  3. Palm m105 Button Replacement: 3 단계, 이미지 1개 중 1개
    • To remove the faceplate, lift the tab located at the top of the device.
    • The faceplate should easily lift off.
  4. Palm m105 Button Replacement: 4 단계, 이미지 3개 중 1개 Palm m105 Button Replacement: 4 단계, 이미지 3개 중 2개 Palm m105 Button Replacement: 4 단계, 이미지 3개 중 3개
    • Using a T-5 Torx screwdriver, remove all four screws located on the back of the device. Turn counterclockwise to remove screws. The link to purchase this screwdriver is located at the top of this page.
    • Once you have removed all four screws, the device will be in three separate pieces (the back, the computer, and the button board).
    • Take caution as the power button will become loose after this step is completed.
  5. Palm m105 Button Replacement: 5 단계, 이미지 1개 중 1개
    • After step four, locate the button board. The button board should have a frame attached to it. Remove this frame.
    • To remove the buttons from the frame, apply even pressure on two buttons at a time. This should make them pop out easily. Once you have removed the buttons, you can now wash or replace them.
    • To insert a new set of buttons, push it back into the opening on the faceplate, and you should feel it click into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Erik Thompson
회원 가입일: 10/04/11
31 평판
안내서 5개를 작성함
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 677
