주요 콘텐츠로 건너뛰기
Palm m105 Display Screen Replacement
필요한 것
  1. Palm m105 Display Screen Replacement, Display Screen: 1 단계, 이미지 1개 중 1개
    • Flip the protective cover open and pull it straight away from the device to release the two clips.
  2. Palm m105 Display Screen Replacement: 2 단계, 이미지 1개 중 1개
    • To remove the faceplate, locate the tab at the top of the device.
    • Lift the tab upwards with your finger.
    • The tab releases easily. Excessive force is not required.
  3. Palm m105 Display Screen Replacement: 3 단계, 이미지 2개 중 1개 Palm m105 Display Screen Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    • Using a T5 Torx screwdriver, remove the four screws located on the back of the device.
    • With the screws removed, the device is separated into two parts (the empty back cover and the back case holding the main components).
  4. Palm m105 Display Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Be careful with this step. The motherboard and screen are attached by fragile cables.
    • Slowly lift the motherboard and the screen from the back case.
    • Gently hold the screen back so that you see the cables between it and the motherboard.
  5. Palm m105 Display Screen Replacement: 5 단계, 이미지 2개 중 1개 Palm m105 Display Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Detach the screen from the motherboard by carefully pulling up on the three tabs.
    • Be careful. These tabs are fragile.
    • The motherboard and screen separate once the three tabs are released.
    • Recycle the old screen.
결론
작성자
7다른 기여자 명과 함께
Erik Thompson
회원 가입일: 10/04/11
31 평판
안내서 5개를 작성함
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 867
