주요 콘텐츠로 건너뛰기
Palm m500 Battery Replacement
필요한 것
  1. Palm m500 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 Battery Replacement: 2 단계, 이미지 1/2 Palm m500 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 Battery Replacement: 3 단계, 이미지 1/3 Palm m500 Battery Replacement: 3 단계, 이미지 2/3 Palm m500 Battery Replacement: 3 단계, 이미지 3/3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 Battery Replacement, Battery: 4 단계, 이미지 1/3 Palm m500 Battery Replacement, Battery: 4 단계, 이미지 2/3 Palm m500 Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Brandan Williams
회원 가입일: 01/11/11
157 평판
안내서 1개 작성함
Cal Poly, Team 14-9, Forte Winter 2011 Cal Poly, Team 14-9, Forte Winter 2011 회원
CPSU-FORTE-W11S14G9
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 43
전체 시간: 4,991
