소개
The purpose to this guide is to show how to properly replace the screen on a Palm V.
Heat the left and top edges with hairdryer for one minute.
Move hairdryer back and forth to evenly heat up surface.
Caution: directly heating the screen can melt or distort the screen.
Use tweezers to hold Palm right side down on it's side.
Use a plastic opening tool to pry open front and back casing.
If you are unable to open you may need to heat with hairdryer for longer.
Be sure not to touch case directly with fingers, it will be hot!
Now pry open front and back casing with plastic opening tools.
Separate front and back casing completely.
Power button will fall off once front and back casing have been removed. Be sure not to lose it.
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
Now you must flip up the adjacent clamp as well, using tweezers like before.
After the clamp is flipped you can gently remove the second ribbon with tweezers.
Before removing the screen you must detach one more wire, the battery connector.
Using the tweezers, squeeze the connector attached to the wire and genlty pull.
Do not pull from the wire.
해당 안내서 퍼가기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
단일 단계
전체 안내서
소형 - 600px
중형 - 800px
대형 - 1200px
미리보기
