주요 콘텐츠로 건너뛰기
Palm v Outer Case Replacement
필요한 것
  1. Palm v Outer Case Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
    • Lay device face down on surface.
  2. Palm v Outer Case Replacement: 2 단계, 이미지 2개 중 1개 Palm v Outer Case Replacement: 2 단계, 이미지 2개 중 2개
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Outer Case Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Outer Case Replacement: 4 단계, 이미지 1개 중 1개
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Outer Case Replacement: 5 단계, 이미지 3개 중 1개 Palm v Outer Case Replacement: 5 단계, 이미지 3개 중 2개 Palm v Outer Case Replacement: 5 단계, 이미지 3개 중 3개
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
결승점
작성자
4다른 기여자 명과 함께
Anthony Platt
회원 가입일: 02/09/10
66 평판
안내서 3개를 작성함
Cal Poly, Team 13-25, Maness Winter 2010 Cal Poly, Team 13-25, Maness Winter 2010 회원
CPSU-MANESS-W10S13G25
4 회원들
안내서 4개를 작성함
1가이드 댓글
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 1,751
