주요 콘텐츠로 건너뛰기
PalmOne Zire 72 Control Pad Replacement
필요한 것
  1. PalmOne Zire 72 Control Pad Replacement, Control Pad: 1 단계, 이미지 1/2 PalmOne Zire 72 Control Pad Replacement, Control Pad: 1 단계, 이미지 2/2
    • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
  2. PalmOne Zire 72 Control Pad Replacement: 2 단계, 이미지 1/1
    • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • If you peel the entire adhesive off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
    • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
  3. PalmOne Zire 72 Control Pad Replacement: 3 단계, 이미지 1/1
    • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
  4. PalmOne Zire 72 Control Pad Replacement: 4 단계, 이미지 1/1
    • Use either end of the spudger to carefully pry off the camera lens mesh cover.
  5. PalmOne Zire 72 Control Pad Replacement: 5 단계, 이미지 1/1
    • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
  6. PalmOne Zire 72 Control Pad Replacement: 6 단계, 이미지 1/2 PalmOne Zire 72 Control Pad Replacement: 6 단계, 이미지 2/2
    • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
    • Gently remove the case to avoid damaging it. Do not try to force the case open.
    • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
  7. PalmOne Zire 72 Control Pad Replacement: 7 단계, 이미지 1/2 PalmOne Zire 72 Control Pad Replacement: 7 단계, 이미지 2/2
    • Remove the cover by lifting it from right to left.
    • This should be similar to the action of the opening of a book.
    • The brown film connecting the motherboard to the screen may tear if this is not done carefully.
  8. PalmOne Zire 72 Control Pad Replacement: 8 단계, 이미지 1/1
    • Lift the control pad buttons off of the motherboard.
결론
Michelle Medina
회원 가입일: 04/10/12
63 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-49, Amido Spring 2012 Cal Poly, Team 6-49, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G49
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 425
