주요 콘텐츠로 건너뛰기
Panasonic ARC ES-LT3N Power Button Replacement
필요한 것
  1. Panasonic ARC ES-LT3N Power Button Replacement, Back Casing: 1 단계, 이미지 2개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement, Back Casing: 1 단계, 이미지 2개 중 2개
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Power Button Replacement: 2 단계, 이미지 2개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Power Button Replacement: 3 단계, 이미지 2개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Power Button Replacement: 4 단계, 이미지 2개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
  5. Panasonic ARC ES-LT3N Power Button Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
  6. Panasonic ARC ES-LT3N Power Button Replacement: 6 단계, 이미지 1개 중 1개
    • Remove battery case.
  7. Panasonic ARC ES-LT3N Power Button Replacement: 7 단계, 이미지 2개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 7 단계, 이미지 2개 중 2개
    • Remove old battery by lifting the battery up and left.
    • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
  8. Panasonic ARC ES-LT3N Power Button Replacement, Power Button: 8 단계, 이미지 3개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement, Power Button: 8 단계, 이미지 3개 중 2개 Panasonic ARC ES-LT3N Power Button Replacement, Power Button: 8 단계, 이미지 3개 중 3개
    • Remove the 8 mm screws directly below the lock switch.
  9. Panasonic ARC ES-LT3N Power Button Replacement: 9 단계, 이미지 3개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 9 단계, 이미지 3개 중 2개 Panasonic ARC ES-LT3N Power Button Replacement: 9 단계, 이미지 3개 중 3개
    • Push the lock switch upward and remove the 6 mm screw hidden beneath.
  10. Panasonic ARC ES-LT3N Power Button Replacement: 10 단계, 이미지 2개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the lock switch by sliding it downward until it is out of place.
  11. Panasonic ARC ES-LT3N Power Button Replacement: 11 단계, 이미지 3개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 11 단계, 이미지 3개 중 2개 Panasonic ARC ES-LT3N Power Button Replacement: 11 단계, 이미지 3개 중 3개
    • Starting from the bottom, lift the front casing upward to separate the case from the device.
    • Continue to lift the device upward until you can pull the casing off.
    • It may take some wiggling or slight bending of the plastic to remove all the way.
  12. Panasonic ARC ES-LT3N Power Button Replacement: 12 단계, 이미지 3개 중 1개 Panasonic ARC ES-LT3N Power Button Replacement: 12 단계, 이미지 3개 중 2개 Panasonic ARC ES-LT3N Power Button Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the button.
결론
작성자
2다른 기여자 명과 함께
Andrew Trainor
회원 가입일: 03/05/17
648 평판
안내서 5개를 작성함
UMass Dartmouth, Team S8-G3, Catania Spring 2017 UMass Dartmouth, Team S8-G3, Catania Spring 2017 회원
UMASSD-CATANIA-S17S8G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 12
전체 시간: 627
