주요 콘텐츠로 건너뛰기
Panasonic Bread Bakery SD-251 Belt Drive Replacement
필요한 것
  1. Panasonic Bread Bakery SD-251 Belt Drive Replacement, Preparations for work: 1 단계, 이미지 3개 중 1개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Preparations for work: 1 단계, 이미지 3개 중 2개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Preparations for work: 1 단계, 이미지 3개 중 3개
    • Make sure the machine is not under power and
    • remove the inner container
  2. Panasonic Bread Bakery SD-251 Belt Drive Replacement, Removing the lid: 2 단계, 이미지 3개 중 1개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Removing the lid: 2 단계, 이미지 3개 중 2개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Removing the lid: 2 단계, 이미지 3개 중 3개
    • Remove the screw on the left side of the hinge of the lid (whith a philips 1 screwdrive)
    • After the screw is removed, you can move the lid (in open position) to the other side and slide it off the hinge (removing the lid completely)
  3. Panasonic Bread Bakery SD-251 Belt Drive Replacement, Remove the screws from the bottom part: 3 단계, 이미지 3개 중 1개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Remove the screws from the bottom part: 3 단계, 이미지 3개 중 2개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Remove the screws from the bottom part: 3 단계, 이미지 3개 중 3개
    • Turn the complete machine upside down
    • Remove the four (PH1) screws from the four rubber stands.
  4. Panasonic Bread Bakery SD-251 Belt Drive Replacement: 4 단계, 이미지 3개 중 1개 Panasonic Bread Bakery SD-251 Belt Drive Replacement: 4 단계, 이미지 3개 중 2개 Panasonic Bread Bakery SD-251 Belt Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two normal screws from the shorter sides (normal PH1 screws)
  5. Panasonic Bread Bakery SD-251 Belt Drive Replacement: 5 단계, 이미지 3개 중 1개 Panasonic Bread Bakery SD-251 Belt Drive Replacement: 5 단계, 이미지 3개 중 2개 Panasonic Bread Bakery SD-251 Belt Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two torx screws from the longer sides (T20 S2)
  6. Panasonic Bread Bakery SD-251 Belt Drive Replacement, Reveal the inner side: 6 단계, 이미지 3개 중 1개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Reveal the inner side: 6 단계, 이미지 3개 중 2개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Reveal the inner side: 6 단계, 이미지 3개 중 3개
    • When all screws are removed from the bottom side, the metal cover can be simply lifted up, and the motor is visible
  7. Panasonic Bread Bakery SD-251 Belt Drive Replacement, Belt Drive: 7 단계, 이미지 3개 중 1개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Belt Drive: 7 단계, 이미지 3개 중 2개 Panasonic Bread Bakery SD-251 Belt Drive Replacement, Belt Drive: 7 단계, 이미지 3개 중 3개
    • With the help of the 8 mm wrench, remove the bolt from the black plastic gear wheel
    • lift the black gear wheel up and the belt drive can be replaced
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bango Bejla
회원 가입일: 11/08/16
1,367 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 22
전체 시간: 897
