주요 콘텐츠로 건너뛰기
Panasonic Camera DMC FX37 Battery Door Replacement
필요한 것
  1. Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: 1 단계, 이미지 1/2 Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: 1 단계, 이미지 2/2
    • Set the switch on the battery door to "open," and open the door.
  2. Panasonic Camera DMC FX37 Battery Door Replacement: 2 단계, 이미지 1/1
    • At the left hand side, locate the head of the metal bar that holds the spring in place.
  3. Panasonic Camera DMC FX37 Battery Door Replacement: 3 단계, 이미지 1/1
    • Push the metal bar down using the metal tweezers.
  4. Panasonic Camera DMC FX37 Battery Door Replacement: 4 단계, 이미지 1/1
    • Pull the metal bar that holds the spring in place out.
    • You can also use tweezers for this step, although we found it easier to just use our fingers.
  5. Panasonic Camera DMC FX37 Battery Door Replacement: 5 단계, 이미지 1/1
    • Remove the battery access door from the device.
    • In order to keep the "springiness" of the door, be sure that the long arm of the spring is not over the hole for the battery.
결론
Zhentao
회원 가입일: 01/30/18
247 평판
안내서 2개 작성하였습니다
Baylor, Team S2-G3, Johnson Spring 2018 Baylor, Team S2-G3, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 250
