소개
Be sure to remove the battery and SD card before opening the camera to get to the motherboard.
필요한 것
Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
It may feel like you are breaking the camera, since the frame makes a snapping sound as you remove it. However, as long as you are careful to remove the frames individually as shown, the frames will probably not break.
Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
As in the previous step, it may seem like you are breaking the camera, because the frame makes snapping noises, as you pull it apart.This is to be expected, and will not harm the camera.
